Unfortunately, EMG passive tone controls never seem to do very much. On the old, hard-wired type, it was possible to remove and replace the capacitor. On the Solderless PCB versions, it is not.
I get my DG20 type sounds from a modified Charvel Model 3. This has two EMG-SLV and one HA pickup, running through a volume pot and an -SPC mid booster. When I want a smoother tone, I pick nearer to the end of the fingerboard.
it's a bit odd, it's like you're adding a scooped mid Blackface kind of tone, then adding some mids to thicken it
end result sounds great, but then you can't lose the treble without changing everything else too
This is why I put separate bass and treble EQ on a guitar I specced myself
IIRC it predated solderless, but the controls are all in one block I think
something like this:
There's not really any space left for more pots
Ged Green said there was some little flat wheel one you could get that just protrudes from under the scratchplate
but is it easy to predict the best component values to use?
