I bought a Jackson a few months ago but was slowly getting familiar with it before checking the setup. I have found that my A string is about .5mm lower than the E or D and the B is similarly below the E and G. I have checked and there don't seem to be any shims under the saddles. Also some of the saddles sit higher, as if the fine tuner is out, but it's not, I keep the fine tuners at the same height but some of the saddles seems to be sitting at an angle so higher than others.
I read about buying shims, is there anything else that could raise or lower a saddle so much? Thank you
E & E Lowest
A & B Medium
D & G Highest
That gives you the standard 10" or 12" radius with or without the shim fitted under the middle for saddles.
To do this...would I need to remove the string, unlock the bolt holding the saddle in place, then lift saddle to see shim, and then just put it all back the way it was? Hopefully leaving the springs attached won't be a problem, I'd be doing one at a time anyway.
Slacken the fine tuners all the way out/up/down in pitch to reduce the downward force on the string clamp locking bolt.
Are the saddles machined from steel or cast in zinc? Some budget conscious FR-licensed double locking vibrato bridges seem to employ a material with all the wear resistance of Stilton cheese.
Having said that, my personal preference is still for Kahler, six-screw fulcrum and the Fender Floating Tremolo vibrato à la Jazzmaster and Jaguar - albeit with Staytrem upgrades.
This is after you get them in the correct order first
They are really thin so they can be stacked if you need them.
