Thanks for that I'll proceed with caution.
Valves ordered, and fuse sourced, collecting from a local hardware store! Thanks once again.
Where the confusion arises is that there are some which do retain fully-charged caps with dangerous voltages if you turn the standby off first, then the power - and others where turning the standby off first is the safest. It all depends on whether there are caps upstream of the standby switch or not, and whether those caps have resistors on them.
At the end of the day, as long as you *also* do the standard safe working practice of never touching the amp with both hands at once when you're working on the circuitry - which is why many old-school techs deliberately put the other hand in their back pocket when doing that - then you're extremely unlikely to come to any harm.
I know, there is a huge amount you need to learn and it can be very confusing at first. Most of us who work on amps for a living have occasionally learned some of it the hard way, which is why the back pocket rule matters.
You're correct that the most dangerous is one hand touching something live and the other touching something grounded, like the amp chassis - even if it's not connected to the mains earth, that will complete the circuit - the current will flow straight across your chest and can indeed be fatal even at quite low currents, around 30mA is enough.
