That not a dig at Creamery, I have them on 2 guitars also. Buyers expectations are usually conservative.
If the volume control is not turning all the way off, before you replace it, get some narrow-nose pliers and squeeze the rivet on the ground terminal hard onto the track board. This problem is usually caused by the rivet being strained when the tab is bent back to solder it to the pot casing.
