2016 Wildwood spec 59 ES-330 -
£2500Finish Color: Dark Vintage Natural
Finish Type: Hi Gloss 90 Sheen Lacquer - Finished in VOS
Bracing: Adirondack Red Spruce Bracing
Top Wood: 3-Ply Highly Figured Maple/Poplar/Maple
Back & Sides Wood: 3-Ply Highly Figured Maple/Poplar/Maple
Neck Wood: 1-Piece Mahogany
Neck Joint: Hot Hide Glue Neck Joint
Neck Shape: 1959 Rounded Profile
Neck Dimensions: .880 1st - 1.020 12th
Fingerboard: Rosewood with Rolled Neck Binding
Fingerboard Radius: 12"
Inlays: Dots
Frets: 22
Scale Length: 24 3/4"
Nut Material: Nylon
Binding: Single-Ply on Top and Back
Pickups: P-90s wound to Wildwood Spec
Controls: 2 Volume, 2 Tone, 3-Way Selector Switch
Hardware : Nickel
Bridge: ABR
Tailpiece: Trapeze
Tuners: Kluson with White Buttons
Case: Gibson Hardshell and Certificate of Authenticity
2016 Danocaster single cut (tele) in Teal Green Metallic with 64 profile neck and T60 Florence voodoo pickups -
£2800Ordered directly from Dan. I really have enjoyed this guitar, but it's time to slim down.
Lightweight ash body (6.9lbs) with teal green metalloic relic finish. 64 neck profile (.86 C), T60s peter florence Voodoo Telecaster pickups. Rosewood fretboard.
Comes with original tag and softshell danocaster case, will also include a Mono case.
https://www.flickr.com/photos/18008378@N00/albums/72157696025426810------------------------------------------------------------
2012 - 30th anniversary Fender Japan 62 telecaster reissue -
REMOVEDModel name TL62B VSP. One of a total of 60 built for this series.
Specs:
Finish: Nitrocellulose
Body: Select Alder 2 piece w/Ivory Binding
Neck: Select Maple
Neck Shape: 60s C neck
Fingerboard: Select Rosewood
Frets: 21F, Vintage
Radius: 7.25"
Nut Width: 42mm / 1.65354"
Pickups: Fender Alnico Custom TL (Japan) x 2 (flush polepieces on the bridge like an early 50s pickup)
Controls: Master Volume, Master Tone (CTS), 3 Way PU Selector (USA)
Bridge: 3 Section 8 Spiral Saddle
Tuners: MHG-SD91 NI
Color: Faded 3 Tone Sunburst
https://flic.kr/s/aHsmHERfPh------------------------------------------------------------
2016 Fender Custom shop Masterbuilt 68 thinline Telecaster by Greg Fessler as new -
REMOVEDMasterbuilder: Greg Fessler
Features:
- Josefina fender custom handwound 60s telecaster pickups
- Lightweight Mahogany thinline body
- Telecaster one piece maple neck with 10/56 V profile
- Kluson tuners
- Nitrocelulose NOS lacquer finish
- Original black hardshell case with case candy and certificate
https://www.flickr.com/photos/18008378@N00/albums/72157702153363072------------------------------------------------------------
2014 Crews KTR Select Aged lemon burst. Limited edition of 12 guitars, built with 4A grade maple top, honduran back and neck and K&T NFS pickups. Original hardshell case and spec sheet. -
SOLDhttps://www.flickr.com/photos/18008378@N00/albums/72157696025426760
GLWTS
https://youtube.com/@alexfarranguitar
https://instagram.com/alexfarranguitar
One of their lovely technicians, will be there to help you.
