Rift Amplification
Brackley, Northamptonshire
www.riftamps.co.uk
But if you don't have access to one, the 6L6WGB is rated for a maximum plate dissipation of 26W, so you should bias no hotter than 18W, or 44mA if the HT voltage is the same as a vintage 5E7 (410V). ~45mA if measuring cathode current. But I wouldn't bias GCs any hotter than that anyway, since the bias point is determined by the circuit and not by the maximum rating of the valve if you use a higher-rated type than the circuit was designed for.
Make sure the amp is set for 240V first, if it has that option. All Fender amps sold in Europe are set to 230V and run slightly too hot in the UK.
Whatever bias point you choose it will shift! New valves these days seem to have excess grid current (not burned in long enough) so you set bias and leave the amp for an hour (I used to run bassy programme through them at 1/2 power) when you come back it will have moved, usually down a bit but sometimes up. Then, bias current depends on the drive "history". Drive the tits off it for ten, especially if you go into clipping, and Ia will be higher and take a minute to fall.
Bottom line, ain't that critical.
Almost all B's amps were biased for 25mA and I never had a request to bias one hotter.
Dave.
Bias point will still shift with programme drive history.
Dave.
