Tuners for a les paul
HootsmonHootsmon Frets: 15962
swapping out the original tuners from my LP cs 58
Image result for headstock les paul cs 58
for a set of Grovers
Image result for headstock les paul grovers
Is it a drop in situation or what?
Thanks guys  :)
tae be or not tae be
  • LestratcasterLestratcaster Frets: 1087
    I'm thinking of doing the same on my LP studio as the stock tuners tend to knock loose too easily causing tuning issues. My other LP has Grovers and its slightly better.
  • HootsmonHootsmon Frets: 15962
    and............How would one go about aging (dulling really) the nickel tuners to match the aged cs Les Paul hardware?
  • ICBMICBM Frets: 72371
    No. You need to bore out the back of the holes to 10mm.
    Most people go all the way through, but in fact you don't need to, and if you stop before you get to the front face it's easier to put the original bushings back if you ever want to.
    Just in case you didn't know - you can get good locking tuners that look just like the original vintage style ones and definitely are just a drop in.
    Re: the Grovers - I'll let someone with exprience of those answer for sure but when I swapped to kind of similar Schaller ones, I had to drill new screw holes because the screw holes were off to the side. I think with those ones being at the bottom it would just depend if they line up with the existing ones or not, looks like they quite possibly would.
    edited June 2019
    Thanks John....what about the 2 screw holes (round back) on the plastic tuners versus the one screw 'ole on the Grovers?
    can i expect this?
  • FarleyUKFarleyUK Frets: 2400
    I'd be interested in these.... any idea which ones exactly? Any links would be appreciated!
    Incidentally; on my main LP I've got the Grovers, but I much prefer the look of the originals - are there any good LP original style tuners that will fit into the hole of the Grovers?
    (Sorry to hijack the thread!)
    You can actually see the topmost screwhole on the second photo you posted.
    Tis cool baby  :)
    It's GOTOH SD90
    The product code for the specific ones that look like the originals but are locking is SD90-SLNMG-T
    A quick Google suggests it might be quite hard to find in stock apart from eBay :(
    The screw on the Grovers should match the lower screw hole on the originals, but that's assuming Gibson lined the original heads up correctly!
    Any particular reason you want to change them?
  • GluedtoMusicGluedtoMusic Frets: 74
    thegummy said:
    It's GOTOH SD90
    Depends if you want the locking wheel on the back or not, sorry to push an advert but we stock locking SD90 tuners without the thumbwheel,
    Schaller G-Series tuners will fit the 10 mm holes or Faber Kluson style with bolt bushing will as well.
    Supplier of Gotoh, Fender, Gibson, Faber, Schaller, Hipshot, Floyd Rose, TonePros, Graph Tech, Hosco luthier tools and many more.
    LOL you're gonna think this is MAD but i was watching an episode today of TPS,an episode called,Dan's Les Paul :)
    and the sight of his cs 58 with the Grovers on left me weak at the knees
    Yes, you're mad :).
    If they were a drop-in fit it would be sensible, but given that there's nothing wrong with the stock tuners and it will need wood removing from the headstock, don't.
    bump
    Oops, bumped the wrong thread  :)
