70s 3 bolt strats converted to 4 bolt?
John_PJohn_P Frets: 2752
Was it common place to convert a 3 bolt neck joint to a 4 bolt?    I can see how a badly fitting neck that isn’t very stable would benefit, if it’s done well but I’ve only come across a couple and in both cases it looked a bit unnecessary.
  • ICBMICBM Frets: 72846
    edited June 2019
    Thankfully not that common, and pointless - the problem isn't the number of bolts, it's the fit of the neck into the pocket.
    The correct solution is to either veneer the neck pocket sides, or pin/mesh/sandpaper the floor of the pocket - equally effective if not more so, and doesn't make an ugly mess of the back of the guitar - it's impossible to do well because the four-bolt plate doesn't quite cover the hole for the tilt adjuster screw on the three-bolt, and the two outer holes don't quite line up.
    Three bolts with any of those solutions is more stable than four without.
    I posted this in another thread but it's worth repeating...
  • p90foolp90fool Frets: 31778
    I wouldn't bother converting a 3-bolt guitar, but I do have a 3-bolt CBS neck on a 4-bolt body.
    http://i63.tinypic.com/2i107qs.jpg
    http://i68.tinypic.com/ify809.jpg
  • skullfunkerryskullfunkerry Frets: 4220
    That's a very nice-looking guitar!
  • BeardyAndyBeardyAndy Frets: 716
    I've got one for sale if your interested? ;)
    edited June 2019
    Not for me thanks dude! I'm not really a Strat sort of guy, although I think they look fab
    (And yes, I know my Squier is a Strat, but it has active humbuckers, a Floyd Rose, and the volume knob isn't so close to the bridge)
