New/Old Build - Tele with a Jazzmaster Trem
lovestrat74lovestrat74 Frets: 2530
edited February 2022 in Making & Modding
Okay so I have all the bits (well nearly) now to build a Strelecaster...
1 piece Ash Tele body (HH)
Strat neck - Fender EOB
Bigsby
OX4 and Cremery WRHB pickups
Should be a fun one to do!
The body is from boobooguitars, so it needs a little bit of attention and drilling for bridge etc.  It has belly cut and the neck pocket is routed for a 3-bolt strat neck.  It has a split in the top where the control cavity was routed (hence why it was on booboo's) so I need to glue in a piece of veneer to strength it up.  A really generous chap (anyandy from eBay) supplied me with some offcuts for this job.
The neck is from an EOB signature strat - really nice neck with a great 10/56 profile.  The Bigsby came via @Teyeplayer and the pups from Graham's (guitar classics) parts drawer!
For colour I am thinking of see through white to show off the grain...
I've aged all the hardware - I am not a fan of the shiny, new, polished look. Not sure whether to go naked, use a standard PG or make my own one...
A couple of pics - yes,
 I know it's all wonky
  • munckeemunckee Frets: 12399
    Never played a tele with a bigsby but they look so cool.  Must weigh the same as a ford focus though!
  • Winny_PoohWinny_Pooh Frets: 7774
    edited July 2019
    Looks nice so far. I'd personally lose the metal plate seeing as the switch is body mounted and cut a thinline style pickgaurd.
    A bit like this but modified at the switch area.
    I love see through white!
    Here's a strat I just finished:
    I used manchesterguitartech rattle cans.
    Grain filled (esp with an ash body)
    1x can sanding sealer
    2x cans transparent white
    1x can clear
    You could also do another clear coat for a less sunk in and smoother finish.
  • lovestrat74lovestrat74 Frets: 2530
    You'd be surprised, they aren't that weighty matey ;)
    Looks nice so far. I'd personally loose the metal plate seeing as the switch is body mounted and cut a thinline style pickgaurd.
    I like the p bass plate, it just adds something a bit different - saying that it might get the bullet if the pots don't stretch far enough  :o
  • TheMarlinTheMarlin Frets: 7885
    Bigsby is made from Aluminium. So they are not massively heavy. People think they are kilos of steel, but not so.
    1x can clear
    :+1:
  • GoldenEraGuitarsGoldenEraGuitars Frets: 8823
    Not in the slightest... just weighed my fender branded B5 at 10.4oz.
  • stickyfiddlestickyfiddle Frets: 27113
    1x can clear
    Tell me more about the Strat with firebird pickups. Preferably via the medium of “leaving it at my house and forgetting where I live”?
    Lovely! I missed the final stages of that thread. Looks brilliant. I'm considering a minihum/fb config in a Jag build I'm mulling
    Okay made a bit of progress today.  Cut out some veneer to strengthen the control cavity as there is a split in the top and the top is on 2mm thick.
    This will be glued and clamped later today.
    Also decided to add an arm cut seeing as the belly cut was already done.
  • KittyfriskKittyfrisk Frets: 18829
    OK, I'm feeling a bit dim.
    You call it a Strelecaster, but apart from the Bigsby, isn't it essentially a Telecaster Deluxe copy?
    Not criticising, just curious.
    Well it's a bit strat and a bit tele a bigsbystrelecaster
    Well it's not official just a bit if fun mate. It has body contours and a Strat neck so there is the strat part. Body shape is single cut tele so there us your tele bit
     Put the 2 together and you get Strelecaster  :o
    Not really a deluxe. A deluxe has a les Paul toggle placement and 4 pots ;)
  • Real slow burner this one.. neck is on (converted from 3 to to a 4 bolt) and Bigsby is on.  Not sure if I should have moved it further back but as I understand, so long as the bridge (next to be fitted) is in the right place the Bigsby position from the bridge doesn't really matter...
  • Like a Phoenix from the ashes this long and winding build is back up and running again!! I wasn't a fan of the Bigsby but I knew it needed something different so I snagged a Descendant trem, a Mastery and some some thimbles (courtesy or @CFH @Dazza & @Springywheel ) and got the router out - no going back now  :o
    I need to drill for the posts for the Mastery next. Also need to realign the trem unit a couple of mill to the right (PITA!!) as it's not quite perfect.
    Looking at getting some tonerider P90s - hot for bridge and vintage for neck - now that the pickup routes have been opened up. Or might look for something vintage from @Alegree.
    Not sure whether to route for the switch on the top horn or just customise the pickguard to suit the body...
  • DazzaDazza Frets: 93
    @lovestrat74 Loving this mate!
    Thanks @dazza it took me a while to get back into this but I am looking forward to getting it up and running :)
