Okay so I have all the bits (well nearly) now to build a Strelecaster...
1 piece Ash Tele body (HH)
Strat neck - Fender EOB
Bigsby
OX4 and Cremery WRHB pickups
Should be a fun one to do!
The body is from boobooguitars, so it needs a little bit of attention and drilling for bridge etc. It has belly cut and the neck pocket is routed for a 3-bolt strat neck. It has a split in the top where the control cavity was routed (hence why it was on booboo's) so I need to glue in a piece of veneer to strength it up. A really generous chap (anyandy from eBay) supplied me with some offcuts for this job.
The neck is from an EOB signature strat - really nice neck with a great 10/56 profile. The Bigsby came via
@Teyeplayer and the pups from Graham's (guitar classics) parts drawer!
For colour I am thinking of see through white to show off the grain...
I've aged all the hardware - I am not a fan of the shiny, new, polished look. Not sure whether to go naked, use a standard PG or make my own one...
A couple of pics - yes, I know it's all wonky
A bit like this but modified at the switch area.
I love see through white!
Here's a strat I just finished:
I used manchesterguitartech rattle cans.
Grain filled (esp with an ash body)
1x can sanding sealer
2x cans transparent white
1x can clear
You could also do another clear coat for a less sunk in and smoother finish.
• Youtube - https://www.youtube.com/@Goldeneraguitars
Full thread here: https://www.thefretboard.co.uk/discussion/156847/strat-assembly-for-fun-completed-pics#latest
This will be glued and clamped later today.
Also decided to add an arm cut seeing as the belly cut was already done.
You call it a Strelecaster, but apart from the Bigsby, isn't it essentially a Telecaster Deluxe copy?
Not criticising, just curious.
Put the 2 together and you get Strelecaster
Not really a deluxe. A deluxe has a les Paul toggle placement and 4 pots
I need to drill for the posts for the Mastery next. Also need to realign the trem unit a couple of mill to the right (PITA!!) as it's not quite perfect.
Looking at getting some tonerider P90s - hot for bridge and vintage for neck - now that the pickup routes have been opened up. Or might look for something vintage from @Alegree.
Not sure whether to route for the switch on the top horn or just customise the pickguard to suit the body...
