In searching for a replacement for a Classic series MIM Tele that I’ve kind of fallen out of favour with, looking around I’ve found a black 1983 US Strat with white pickguard from the Dan Smith era, but as far as I’ve heard this model isn’t a “proper” Dan Smith model as it has two knobs (volume and tone). Bit of a thin neck but still found it very comfortable to play and it sounds great, the pickups are articulate, very responsive playing into a Blues Jnr. Anything to watch out for with these in terms of build quality? Anyone owned this version?
The Freeflyte vibrato lacked feel or tuning stability. It was also almost impossible to block off properly. The top routed vibrato spring cavity required very little enlargement to accommodate a Kahler Pro flat mount vibrato. I upgraded to locking machineheads rather than a string clamp. Then, for better or worse, I traded the guitar to HarrySeven. As far as either of us knows, he still has it but might not know exactly where it is stored.
They all have very thin, usually slightly v-shaped, necks. Unless it's the rarer hardtail version, the biggest problem with them is the Freeflyte vibrato bridge - it kills sustain and tone, and bits of it can break and are very hard to replace... except by finding another one that someone has already removed from a guitar! Due to the extreme difficulty of replacing the bridge with a standard Strat one, the bodies often get replaced, although it is possible to fit a Kahler, as Funkfingers said - it still requires some woodwork, but not as bad and the result is very 'clean' since the body has no back rout.
If it is the hardtail, it's a much nicer guitar but still worth much less than a real Dan Smith.
Maybe a fair name/tag/description would be 'Fender 1983 USA Strat Standard - Dan Smith Era'
I thought I'd try the Strat into an AC15, as there wasn't a Blues Jnr IV in stock (the amp I have currently), and dear christ it sounded stunning. Complete revelation as far as my tasted go. The guitar was really responsive and articulate, full-sounding and bright but not gratingly bright, nice natural compression and the guitar stayed relatively clean at a healthy volume... SO impressed.
I thought just a few years ago that I was completely content just to use BF Fender amps and offsets/teles, never thought I'd want to go for a Strat and an AC15. Quite a revelation for me (others have probably liked this amp/guitar combo for years).
I'd avoid the two-knob models - full of cost-cutting shortcuts designed to make it cheaper to produce, which is the precise opposite of what Dan Smith and his crew were aiming to achieve when they took over Fender.
I’m in absolutely no rush buy anything right now, though. My MIM Classic Series Tele is up for sale and I’ve got the use of an 80s Tokai Strat my guitar tech housemate repaired for someone years and years ago (for some reason the owner could not be contacted, complete radio silence, guitar not collected). I’m more than happy using the Tokai while I amass funds for a new guitar.
How much is 'reasonably priced'? Personally I wouldn't even pay £500 for a Freeflyte one no matter what era they're from or what some sellers want for them... you can buy a much better Mexican Strat for less than that.
https://reverb.com/uk/item/25964213-1983-1984-fender-stratocaster-elite-freeflyte-tremolo-bar-1983?gclid=Cj0KCQjwyLDpBRCxARIsAEENsrIDNeoUv15DGq75jQgItVBLRpE8-0nVtd7tV3z8zvqaczMwIv6OqYUaAiV_EALw_wcB&gclsrc=aw.ds&pla=1
