If you want to play out loud, you'll need to plug it into an amp of some sort. The Korg isn't an amplifier itself (although it models them) and the output signal won't have nearly enough power to drive speakers.
I used the headphone output of a Mesa V-Twin pedal to drive a cab, which sounded OK.
But unless you have something suitable to hand or can get it for free, you’re as well buying an amp rather than a cabinet. You can pick up a tolerable solid-state amp which will give a usable clean sound for only about £20 or £30 - the quality doesn’t matter too much since you’ll be getting the sounds from the Korg.
