Amp Family Tree?
thegummythegummy Frets: 4389
Is anyone aware of there being a kind of "amp family tree" available online?
I.e. has the main types of amps like Fender, Marshall, Vox etc. then has some examples of amps that are in each category?
E.g. Friedman BE under Marshall.
  • Modulus_AmpsModulus_Amps Frets: 2583
    No but it is a good idea
  • SassafrasSassafras Frets: 30294
    Don't most manufacturers describe their amps as having certain characteristics such as 'vox chime' 'fender sparkle' 'Marshall grind' etc...
  • peteripeteri Frets: 1283
    Well I'm guessing it would mainly start with Fender, that's where Marshall came from!
  • ecc83ecc83 Frets: 1636
    In deed. Now, someone went to the considerable trouble to test and rate over a dozen of the most common "studio" microphones. Listed  with adjectives such as "smooth, bright, dull, heavy,harsh treble, thin" and so on.
    Virtually all valve amps of course trace their lineage back to Fender and the valve data sheets, design mistakes et al! So, there are only so many variants you can do with valves but when you add in voicing  and tolerances it all gets a bit tricky!
    And, does the "tree" give the sound into one specific speaker?
    Dave.
    Dave.
    Sounds like a thesis project now!
  • PolarityManPolarityMan Frets: 7294
    I dont think it will work, My JVM has been sitting on top of my JCA 50h for about a year and a half and they still reproduced.
    ဈǝᴉʇsɐoʇǝsǝǝɥɔဪቌ
  • stickyfiddlestickyfiddle Frets: 27124
    A dirt pedal one could be good too (aka "Everything's a Timmy and a Timmy is a Tubescreamer")
