Open G chords
RockerRocker Frets: 4986
Calling all you chord experts.
Open G tuning is: X G D G B D
What chord is the following: X O 2 O 1 O
This chord is used a lot by The Rolling Stones AFAIK, usually after the open chord has been played.  Thanks.
Nil Satis Nisi Optimum
  • tone1tone1 Frets: 5173
    Yep, that’s definitely the ‘Keef’ Chord
  • martmart Frets: 5205
    C2
  • BahHumbugBahHumbug Frets: 350
    From bottom to top the notes are G E G C D.  C, E and G are the 1sr, 3rd and 5th of C major.  D is the 2nd of C, but because the chord has a 3rd as well as a 2nd it’ll be called an add9, rather than a sus2.  The chord has G in the bass, rather than the root note C, so it’s an inversion.......
    Cadd9/G
  • vizviz Frets: 10700
    Cadd9/G
    Yes.
    Or 37553x on normal tuning.
  • ModellistaModellista Frets: 2041
    edited July 2019
    Because the G remains in the bass I would personally think of it as a G variation rather than a C inversion.  Very commonly used as a suspended-resolution cadence in rock and country - eg the intro to "If It Makes You Happy" by Sheryl Crow.
    G6sus4.
  • bbill335bbill335 Frets: 1382
    Depending on which strings you play, that shape implies Amin[7] too!
  • HAL9000HAL9000 Frets: 9692
    Only in standard tuning. With open G tuning it’s def a C2.
    It's got everything an Amin7 has except the root. You can definitely use that chord for Cmaj or Amin.
