The discussions on tone difference between mahogany from honduras and mahogany from Africa are pretty much featured on every forum I visit, without an conclusions. I think unless you have several guitars from each, the difference is psychological.
I contemplating buying an SG, there are 2 choices, buy new from Japan, african mahogany or buy a used one locally, honduran mahogany. Since the guitar is all mahogany I'm tempted to go for the used one, as it will be cheaper overall, and maybe overall better quality.
But on guitars that are all mahogany, such as the Les Paul Custom, SGs, the Juniors, and acoustics the difference maybe more apparent. What i hear said about Honduran is that it has more low mids, making it sound a bit fuller than African.
Does anyone have both and notice any difference?
Much more important is to buy the one that looks/sounds/feels better.
There will be differences between different pieces, but that will happen within the same species. When I've bought guitars in the past, I've sometimes got 3 or 4 of the same guitar in a room and tried them all out back to back. On a couple of occasions that has been with PRS. The older pickups were all machine wound and would have been identical. Their quality control and set up are as good as it gets, yet there are definite tonal differences between different guitars of the same model - where the wood is likely to all be from the same source.
I think the thing with the classic "Honduras" mahogany is that it is very light, yet still has a similar stiffness to heavier mahogany.
Of course, you should also take into account the thickness of the paint finish on the guitar and whether it was applied on a Friday or not. As everyone knows Friday finishes suck tone.
Then there is the 'are you wearing man made fibres or are your clothes natural fibres' argument etc etc
All of these things have bearing on how your guitar sounds.
Probably...
As for your question, does it make a difference, I personally don't think so. Buy the guitar you like, regardless of the mahogany type.
I do have Navigators, and they sound amazing, one has honduran for sure, and the other one is much older, it doesn't look the same, but it sounds as good if not better so I don't think there are rules. I did read a lot of posts about the magic of older SG's sounding better and fuller, and some say it's down to the honduran mahogany.
Either you get a good guitar or you don't and in some cases when you don't they can me made good, if certain issues are address. In other cases, they're just not great to begin with.
The thing with SG's, they almost all cherry and I found one in Japan that's metallic green, like I wanted for a long time, and if the wood doesn't matter, the color, or the look sure does!
Some things can't be conveniently classified.
But next to pickup / setup / strings / a 0.00005mm eq change I doubt it is important.
I believe there can be tone differences between individual pieces of wood - between densities, between *widely differing* types of wood, possibly grain structure and orientation, and the resulting resonances from the combination of those things. But not inherently between two closely related species of timber.
I dare say most of us can tell the difference between the completed and finished guitar, that has some 'mojo' about it, the way it sounds, sings, sustains - Against a similar guitar that sounds lifeless - But this can happen with 2 pieces of wood from the same forest, let alone from a different country
Most good builders, large or small, can select the wood they prefer for their guitar - The likes of Gibson can keep the better pieces with any lively vibrant qualities, for the 'more expensive' guitars and move lesser grade wood down the line, to more affordable models, to minimise any wastage - Smaller luthiers will be very selective anyway - I dare the likes of @IvisonGuitars , @FelineGuitars , @Danielsguitars , @Rabs etc etc, can pass comment on this - I'm sure they will have a hands on input as to what determines the weight, acoustic tonal character/resonance' and cosmetic status of any wood they select for their guitars
Also remember, the mahogany for the body will have a different density, weight and tonal character/resonance than the mahogany required for the neck (here they will require a stiffer/tighter grain, for strength and stability)
I don't believe in Beatles.
I just believe that, if the sum of a guitar's parts sounds and feels good, I should play the bejeezus out of it.
They imported more African then than anything else, i wish people would get off the honduran is best band wagon, it's either good wood or not imo
For a full carved top i want lighter weight mahogany, if it's well seasoned I'll use it
I've built with african, honduran and old non plantation mahogany, guess what they all came out sounding good apart from one heavier honduran les paul, it was good but just didn't ring enough for me so i took it apart, recently i built another one using old khaya it was same weight as the heavy honduran one finished, night and day difference, the old khaya rings like a bell which threw my weight theory out the window
Construction is another important part of that guitar as a whole, alot of tone comes from a neck too
(formerly customkits)
Even for acoustic soundboards that are made from different species of Mahogany, I can't tell the difference. So for an electric guitar, I think it's even less important.
As for Spanish Cedar, it's choice for classical guitars/nylon string guitars and I read on a few forums the good quality stuff seems thin on the ground, so I imagine it'd be even less seen for electrics in the future.
In one thread it's difficult to tell the difference between totally different types of guitars... and in another you can easily hear that three almost identical Les Pauls don't sound quite the same.
It's like Schrödinger's Cat - both things are true at the same time, even though that's totally contrary to all common sense. (If you're unfamiliar with quantum physics, the cat is *not* either alive or dead - it's both, simultaneously.)
