Of course, if you gig with a Gibson you can always break the headstock off too .
I don't normally take a spare, but I admit I also very rarely play gigs where we're the only band - since I don't do the weddings/functions circuit - so in a real emergency I'm sure I could ask nicely to borrow someone else's guitar... on the grounds that I've quite likely already worked on it at some point, going by the bands we tend to play with!
I'll take an acoustic as a second guitar if the set calls for it.
Have broken strings a few times. In the summer months I've even broken 2 or 3 and had to restring mid song - THAT impressed the drummer! Although my finest moment was breaking a string on the intro to Thing Called Love by the Darkness and managed to switch guitars between the first and second lines of the verse. Sadly everyone had fucked off outside to stand in the sunshine so no one saw what must go down as the greatest rock n roll maneuvre of my life.
One of the major advantages of being a repairer of both amps and guitars (and pedals) is that I get to see what breaks and what doesn't, so I have a very good idea of what I can rely on at gigs and what I wouldn't risk using without a backup.
If they're the same style then no. Just make sure you don't throw the other five away, and possibly keep them in the guitar case... you could actually change one between sets in five minutes with a small screwdriver and a spanner.
Does anyone make a good direct replacement for those tulip button, bolt bushing tuners? There are Grovers and Schallers, I think Faber have them now too, but they all look so similar to the Gibson ones I'm not sure if they're actually the exact same tuners.
TonePros/Kluson made them for a while, but they're not available any more.
As I use a digital rig, I carry a spare preamp, a spare Midi switcher (2 button) and loads of spare cables. Dib dib dib.
There are no other better equivalents with both the same two-screw footprint and a threaded front collar. The only simple alternatives are to use vintage-style Kluson-type pressed-steel tuners (which are much stronger and don't suffer from this) with a conversion bushing, or a different threaded-collar tuner with a different screw fitting - Grover Rotomatics actually fit the lower of the two holes so you don't need to drill anything, but they leave the upper one visible, and a lot of people don't like the look or weight of them.
Sorry, this has become a bit of a tuner-specific thread! They really are crap though, and it's one thing that would make me think twice about gigging with a guitar with them, with no backup. Although, I have...
I do take a EHX Magnum 44 as a spare amp solution. Again, never yet needed.
Same with valve amps - the last one I gigged with had two separate channels, two speakers, four power valves and even two rectifiers - with just a couple of spare fuses I could almost certainly have got it going again just by pulling or disconnecting whatever was faulty.
It's also one of the things I try to make sure of with any band I've been in - everyone else's gear needs to be similarly reliable, and if that means replacing jacks with top-quality ones, cables with good ones, providing spare power supplies, etc etc, then I've always been happy to do it - I'd far rather fix things in advance and not have to worry about it on stage than the other way round.
You can get one of those G-force/robot sets. Everyone hates on them for some reason so they're cheap. I got mine off here for a decent price. A set of replacement Gibson Deluxes (I couldn't find anyone selling a single) will cost far more than the robots and I quite like them, too.
Even if you only use them as a built-in string winder, I've really liked using them and they took minutes to fit. Plus it's completely reversible if you change your mind - no screws or drilling required!
On a gig, our singer once managed to break the headstock clean off a Gretsch I had at the time, and not a cheap Gretsch either, it was a Malcolm Young Signature model.
Always two guitars at gigs for me, but I like to swap anyway just because I can.
