Turns out there is an H in Haych! ~ Sporky
Bit of trading feedback here.
Rift Amplification
Brackley, Northamptonshire
www.riftamps.co.uk
Assuming the usual arrangement where the filaments are daisy chained in parallel, then you can use thinner wire for the pre-amp valves as current passing through the filament wire diminishes down the daisy chain.
18 AWG is rated to handle 16 A for chassis wiring (and this rating is conservative).
So say 4 x 12A*7s and 2 x 6V6 would require 2.1 A of filament current in total (4 x 300 mA + 2 x 450 mA), and 1.2 A for the 4 pre-amp valves.
18 AWG is total over kill (not a bad idea mind), but you could use 18 AWG for the power valves and say 22 AWG (current rating 7A) for the pre-amp valves perfectly safely.
Will the the fact that I’m using 6L6s make any difference at all?
