The Deltone is a 6V6/6L6 based, 22/30 Watt, single 12" combo. It is the result of requests from longstanding customers to build a black line series to emulate the beautiful sounds of the pre-CBS black amplifiers. The Deltone is a true two-channel amp with two inputs for each channel. One channel offers a straight sound and the other channel offers vibrato and reverb.
The Tremolo circuit was modified from the opto-coupled or photo-cell tremolo circuit in the blackface amps and moved to a bias modulated circuit. This change provides a more pleasing and warmer sound to the ear.
The Normal and Vibrato channels of the Deltone has volume, treble, bass, reverb, speed, and intensity. The Vibrato channel has an additional middle control. The original blackface deluxe amp did not have a middle control. The middle control is a great addition as it provides more control for the player's midrange sound.
The Deltone comes standard with a 6V6 tube configuration. The amp can accommodate a 6L6 configuration with 35 Watts of output power. An additional feature with the 6L6 configuration is a 4k/8k option. This allows the player to simply switch the load to provide a cleaner or more distorted sound. The 4k option provides cleaner tones, while the 8k option will lower the wattage and provide quicker mid-range break up.
No box so collection only from close to Witney, Oxfordshire.Base theme by DesignModo & ported to Powered by Vanilla by Chris Ireland, modified by the "theFB" team.
I have owned some Louis amps before,top notch build quality.
I bought your headstrong 4 yrs ago!!
GLWTS.
