Personally, I would never 'expect' any venue to have anything. Way too much of a gamble.
If however you are going through the POD then you do not need a DI box as well.
This means that you can drive the signal a long distance to the desk without any loss of tone and without any crackling on the cable.
There are two types of DI, [1] Passive where a high quality audio transformer does the job. These are never cheap unless the transformer is sub standard and are best used for outputs that are already active like keyboards or drum boxes. [2] Active where a circuit does all the jiggery pockery (sometimes with a mini transformer included) and takes the power it requires from a battery or from the mic line as phantom power. These are best suited to passive signals like a guitar/bass.
The Pod and other similar units incorporate the active circuitry of a DI within them and mean you don't need an additional unit.
Most House Sound systems have there own DI boxes so unless you band require lots for banjos, fiddles, etc. you should be fine. If you want to carry a light-weigh good quality active unit just in case, try Orchid electronics with there micro DI box at £25 or their classic DI for £36. Both are quality sound at sensible prices and John Godsland is a very helpful bloke that stands behind his product.
soundcloud.com/thecolourbox-1
Lots of bassists use picks, including me generally. Just surprised no amp, but that explains it. I would be tempted to get an amp s/h even if you use it as a monitor. Most decent bass amps have a DI built in anyway.
As per the above don't buy the Orchid micro di for bass duties buy the classic because this allows you to split the signal as per @ICBM 's comment.
