Best gunk for reconditioning rosewood fretboards?
RichardTRichardT Frets: 71
My acoustics, Gretsch & Peavey fretboards seem to be self-maintaining courtesy of greasy mitts & cleaning & the odd lemon oil dab but I've just acquired a Guild Blues 90 (really nice guitar, as it happens), which has obviously sat unloved, unplayed, cased and centrally heated for years. Has responded well to TLC but the fretboard is pale and obviously fairly dry, so I'm thinking it could use something more to penetrate the grain. Fret Doctor gets lots of upticks but it's fairly pricey over here, any other bright ideas?
«13
    boiled linseed oil.  Slop it on and leave it soak in, then clear away residue. 0000 Wire wool & lemon oil to finish.
    Feedback
  • PonchoGregPonchoGreg Frets: 764
    Music nomad F-One oil is good
    Click here to see me butchering some classic solos!
  • SkippedSkipped Frets: 2371
     Fret Doctor does darken so I concluded that maybe it was worth the money.
    The small bottle goes a long way, but I seem to recall I had to use the "email when back in stock" option.
  • mark123mark123 Frets: 1325
    edited July 2019
    £35.95p !!!!! o
  • HAL9000HAL9000 Frets: 9702
    ^ This. Music Nomad products do seem to be consistently good.
  • RichardTRichardT Frets: 71
    edited July 2019
    "   £35.95p !!!!! o  "
    Heh, yes, that was my reaction. But daft I know given the £ all the gear owes me but the F-One is looking a bit less extravagant!
    Always a bit leery of linseed oil,as I understand it it effectively seals the wood surface. Plus there's the spontaneous combustion thing, I'm accident prone.
  • ZoolooterZoolooter Frets: 887
    It thought linseed formed a film on top rather than sinking in.
  • CorvusCorvus Frets: 2929
    Lemon oil here, I've a couple of guitars that've been getting it since the late 80s, ignore internet fake news about softening wood and such. I get Mansons when poss, Hugh makes his own brew, about a fiver. Or used to, he's retired now I think.
    Since being in the habit of wiping strings with an XLR8 pad I don't get any gack building up on the board. When the pads dry I squirt Kyser Stringfellow on, same difference. Strings last better too.
    Linseed does dry to a film but I also use a super thin wipe of it to seal in a newly-dyed board. Bit of lemon oil when dried and it gets a lovely sleek smooth feel. AFAIK it can ignite organic fabric rags but I've never felt them even get warm.
  • ESBlondeESBlonde Frets: 3594
    Boiled linseed will harden so wipe off the excess thouroughly. It leaves a lovely finish imho.
    A great product for the fingerboards is bore oil. It is the basic ingredient in all the proprietery fingerboard conditioners. Buy it from a woodwind shop where it's used to condition woodwind instruments or from a chemists. You can even use it on your bagpipes! Or if someone else does you can clean your shotgun stock with it afterwards....
    Finally a non to messy option. Get a wet walnut and rub the inner nut on the fingerboard. It has a mild but soft rubbing/cleaning action and leaves a light layer of nut oil as a conditioner.
  • Mark1960Mark1960 Frets: 326
    Almond Oil is the best thing I've found for Rosewood Fretboards.
  • SassafrasSassafras Frets: 30301
    Walnut or a brazil nut rubbed over the board works quite well.
  • KittyfriskKittyfrisk Frets: 18867
    Does this work for non Brazilian boards?
  • rze99rze99 Frets: 2296
    Bore oil is inexpensive and perfect for this. If it is still too light for tour tastes you could use leather dye to ebonise it or dye a darker shade of brown.
    RichardT said:
    "   £35.95p !!!!! o  "
    Yes, that is too much.
    I suspect that they are permanently re-ordering  the 30ml size (£19.95)  and you would not have to wait long.
  • stickyfiddlestickyfiddle Frets: 27133
    Gerlitz Guitar Honey.
    Don't use lemon oil - it's basically just lemon-flavoured naphtha, which strips and cleans but doesn't "condition" the wood at all.
  • CloudNineCloudNine Frets: 4264
    This stuff has been really good imo, and not crazy expensive. https://crimsonguitars.com/store/fretboard-cleaner-restorative/
    edited July 2019
    The aesthetics don't bother me, pale but healthy is fine - it ain't ebony -  the cowboy chord footprint is distinctly darker so I think the rest will darken a little with any appropriate treatment, which is fine. The body is a gorgeous British Racing Green trans over a subtle maple flame so she's a looker in any case. Will take a look at generic bore oil, that appears to be the basis for Fret Doctor.
    Good to get a range of views on this, thanks all.
    Yes, but it tends to leave a thin strip down the middle!
  • poopotpoopot Frets: 9099
    Baby oil... Tis all you need!...
  • HerrMetalHerrMetal Frets: 546
    Another vote for Music Nomad F1.
