One for you!
Plugged the TRS cable to my Origin switcher into a Vein Tap dual button switch (normally used to turn rev/trem on/off on a Deluxe Reverb). One press of the right button activates Blend Override, another press switches the RD's channels. One press on the left doesn't seem to do much, a second press turns the RD on and off.
So no, doesn't work as the RD's switcher does
I modified a cable following the instructions to use it with my ES-5 and it works alright.
Collision rock band
