I've got a pair of DiMarzio stacked single coils in my Strat, and they make a weird and very unpleasant sound if you hit the low E string too hard. The noise is a bit like digital clipping (so much so that I initially thought my AX8 or digital wireless were at fault).
I've taken it to a tech, who is a bit stumped. He checked and double checked all the wiring, and everything should be fine.
Then he got another guitar in for repair that has the same problem (to a lesser extent), also with DiMarzio stacked singles. It's worse on the neck pickup than the middle (and if you swap the pickups round, it's always whatever's in the neck that sounds worse). The E string is worst, but the A string does it a bit too.
Is this a known issue? DiMarzio tech support suggested adjusting the pickup further from the strings. That seems to reduce the problem but not eliminate it. Do other stacked singles suffer from the same problem, or is this particular to DiMarzio's 'Area' pickup design?
My YouTube channel,
Half Speed Solos: classic guitar solos demonstrated at half speed with scrolling tab and no waffle.
I discovered all of this when I investigated a semi-functional DP116 DiMarzio HS-2. It arrived in the middle position of a HSH shred stick guitar, wired to operate in single coil mode only à la Steve Vai. I soon realised why. The lower coil was broken!
The two plastic bobbins of this pickup are held together with a single cross-headed screw through the underside. If the screw works loose, there could be unwanted resonance.
The published D.C. resistance stat for the DP166 HS-2 is 14.97k. My cruddy old multimeter reads 8.5k for the upper coil alone.
Some Duncan Stack pickups give d.c. resistance readings of ⅔ working coil, ⅓ dummy coil.
The Fender Super 55 pickups were side-by-side coils (and plates) but two-con + shield output cable. They vanished very suddenly. Perhaps, something about the Super 55 construction fell foul of somebody else’s patent?
For the record, the pickups were a Virtual Vintage Heavy Blues 2 neck (DP409, 8.53k) and Injector Neck in the middle position (DP422, 8.56k).
I'll see if I can live with it and how good it sounds through my rig. I have good quality vintage-style true single coils in my other Strats, but I want one noiseless Strat for gigs where vintage pickups are unusable because of dirty power supply or crazy lighting rigs. If these don't do it for me I'll look at alternatives, but I do like the sound they make when they're not farting out.
Thanks @OilCityPickups for generous advice on a competitor's product. I could well end up with some of your custom rails jobbies if these don't work out. Those P90s you wound me are the bomb, by the way!
As said before, they've got a big steel claw around the top coil. The top coil is wound with most of the DCR, bottom has about 1/3 of the resistance (but has same physical coil volume, so it's definitely wound with less turns of thicker wire). The magnets only past through the top bobbin, with the steel claw making the magnetic field very strong at the top. This doesn't make the bottom coil a dummy coil. The idea that the pole / screw inside a pickup is what picks up the sound is false. What this makes is a top coil wound reasonably with thin wire, and very strong magnetic field, and a bottom coil which is wound very modestly (but enough to buck the majority of the hum) with thick enough wire to not influence the tone too much.
Edit: I concur with the prediction of a resonance issue.
Having said that, I like the set I have which are on the warm side of Strat tone.
/nerd
Couldn't find anything. Then 3 posts later you mentioned them.
Also reminds me of the "domino" pickups on PRS EGs, made by Fralin I think. And G&L's Z coils. Like a P-Bass pickup for guitar. Not particularly attractive to look at, though.
http://www.thefretboard.co.uk/discussion/89942/caspercaster#latest
This is how the old Rickenbacker “horseshoe” pickups work.
