I always thought the dt amps were a great idea in theory. My DT25 was very heavy though!
DT50/DT25 Remote
Helix Floor, Helix Rack/Control, Helix LT, HX Edit
Helix can now remotely adjust the real tube topology settings and other parameters in one or two L6 LINK-connected DT25 or DT50 amplifiers. When one DT25 or DT50 is connected via L6 LINK (110-ohm AES/EBU cable), it receives a mono signal from Helix; when two DT250 or DT50 amplifiers are daisy-chained via L6 LINK, the first cab in the chain receives the left signal and the second cab receives the right signal.
TIP: Just like with any amp, cab, or effect parameter, DT parameters can be quickly assigned to footswitches or Snapshots.
simultaneously (“1+2 Link”). Normally, you should leave this set to “1+2 Link,” which edits both DT amps simultaneously, to maintain phase coherence.
DT Channel
When set to Channel A, the DT switches to Channel A and its preamp is bypassed for when using a preamp model in Helix. When set to Channel B, the DT switches to Channel B and its preamp is activated
TIP: Assign a stomp footswitch (or snapshots) to simultaneously bypass a Helix preamp block AND switch a connected DT amp to Channel B. This gives you a wider variety of tones in the same preset, without the DSP overhead required to run two simultaneous Preamp blocks.
DT Topology
Changes the DT amp’s negative feedback loop topology. Choose “I (Tight)” for behavior reminiscent of the great American Blackface amps of the 60s, choose “II (Loose)” for dialing in echoes of classic British amps, choose “III (ZNF)” for a very open or dynamic feeling amp, or choose “IV (Resonant)” to add low frequency resonance that pairs well with high gain tones.
DT Power Amp
Sets the DT amp’s operating class, wattage, and bias type. Choose “Class A” for more dynamics with greater touch sensitivity; choose “Class AB” for greater headroom and power
DT Tube Config
Changes the configuration of the DT’s power tubes. Chose “Pentode” for clear and commanding tone; choose “Triode” for quieter and rounder sounds with a more vintage feel.
DT Reverb
Turns the DT amp’s built-in spring reverb on and off
DT Rev Mix
Determines the amount of built-in spring reverb
DT 12AX7 Boost (DT50 only)
When Low Volume Mode is off, applies a volume boost DT
Feedback Cap (DT50 only)
Sets the DT amp’s feedback capacitor type
DT B+ Voltage (DT50 only)
Sets the DT amp’s phase inverter B+ voltage
NOTE: For more information on DT amps, see the DT25 Pilot’s Guide or the DT50 Pilot’s Guide.
Either way, I got it all working own my DT25 this afternoon and it appears to do what they say.
I assume this wouldn’t work with the HX Stomp? Can’t see it stated definitively anywhere.
Need someone a bit more into Helix to answer all these questions, as I am a Luddite...
