Help removing Poly finish - progress pics and slightly weird results...
johnljohnl Frets: 2011
edited August 2019 in Making & Modding
I'm in the middle of stripping a poly finish from an Epiphone that I've just purchased and it's turning out a bit weird:
The large part on the right is noticeably darker and is the first part I stripped (with originally 80 and then 120 grit sandpaper). The lighter (and much nicer looking) part on the left I did using 140 grit. It still doesn't feel like I'm down to the wood on either part (when looking closely it's like there's a level or two of clear finish above the wood) but as much as I sand the "black" side it doesn't seem to change colour or texture. Any ideas as to how I can rescue this?
  • mrkbmrkb Frets: 6886
    To see if you’ve got to the wood drop some water on it, it will roughen up the grain slightly. The thickness of some finishes is amazing and a colour change doesn’t mean you’ve taken it all off. Also wood dust is different feel to polyurethane dust (which will be white)
    Karma......
    Ebay mark7777_1
  • johnljohnl Frets: 2011
    Thanks @mrkb - looks like I'm still not down to the wood so will keep going for a bit and see what happens.
    Right - crisis averted, further sanding and there is indeed glorious mahogany underneath the black.
  • DeadmanDeadman Frets: 3911
    Looks lovely!
  • thermionicthermionic Frets: 9656
    Be careful - it’s probably a veneer.
    Nope, had a look in the cavities before starting. This one is listed as (and is) full mahogany
    You can usually spot the seams of a multi-piece body on the sides, at least on the Les Pauls. What model is this then?
    It's the Jared James Signature. It's a les paul custom with a single dogear p90. It's a mahogany cap on a mahogany body rather than a single piece but that's how Gibson makes the customs as well these days
    I thought the cap was separate whether it was maple or mahogany anyway. Good to know that the high end Epis are made of good wood.
  • sawyersawyer Frets: 732
    What's the plan? Natural back gold top? That be cool!
  • lovestrat74lovestrat74 Frets: 2530
    Have a wizzo Mr B !
