I'm having a little trouble getting a blackface amp that does what I want. I play in a blues/rock trio and we play a fair volume. I also need a quite a lot of clean headroom to sit about the mix for some clean solos. The super reverb is my favourite amp I've ever had but it ran out of headroom at the gigs i used it for. It broke up just a little to early so when I engaged a clean boost for solos it just compressed. I'm currently using a twin reverb, which is absolutely insane. I've never had it past 2. I need something that has the big lush, scooped blackface cleans of a super but a little more power and headroom.
I've tried the following at gigs and they are either to loud/quiet or don't have the tone I'm after, so are not options;
Fender Super Sonic 22, 60, 100
Fender Vibroverb 63 RI
Fender Deluxe Reverb
Fender Custom Vibrasonic Reverb
Fender Hot Rod or Blues series
Any ideas?
I await the obligatory 'I've never had my deluxe past 3, if that doesn't work, you must be to loud' comments with baited breath
Guitar dealer and G.A.S merchant by day: www.vibrocaster.com
Blues/rock singer & guitarist by night: www.alexhamiltonguitar.com
The super sonic 60 is a great amp! Giggled one for an long time. Unfortunately the circuit comes with a high pass filter so it rolls off all the low end on the 'vibrolux' setting. Even with the bass up full it's missing bottom end. I haven't tried pro sonic or pro reverbs yet, both doable options!
R.e to loud, when I twin is on 2 the power valves are barely doing anything and the amp sounds sterile. An amp that is to loud in my mind is one that I cant turn up loud enough to get the, compression, dynamics, sustain and goodness of tubes that are working hard. Different to distortion!
If you don't have the Super any more, try the Twin running on two power valves. That will produce about 50-60W. Technically you should reset the impedance, but that can't be done without changing the speakers, so I wouldn't worry about it - the result of the mismatch will be slightly more compression anyway, which may help.
The Fender 75 was regarded as 'Fender's Boogie'. It's heavy, loud but has great spanky, Fendery cleans and the overdrive is ok and was a cascading type. It also takes pedals really well and It's from the 80s but WAS NOT a
Rivera-designed one. I thought there was one for sale on here and they come in cheap (under £500)
Alex335's Divided by 13 9/15 JRT combo on here is excellent and there are others like a Dr Z and Carr's should not be discounted.
I'm not far from you (Huby, nr. Easingwold)
R.
Eqd Speaker Cranker clone
Failing that then a Blackface Twin.
Alternately some of the 100w Dumble clones will get you close (TR, Redplate, Fuchs, Bludotone, Ceriatone). Might need a pedal in front that will scoop the mids a little.
http://ampwares.com/amplifiers/fender-75/
Or for the win - A Redplate. Job done.
