I've always been careful with the oily rags because of the combustibilty
Most finishing oils and lacquers have the capability of spontaneously combusting while the cloths that have been used to apply them are drying.
That is because the drying releases the volatiles in them and (I think) the drying process generates heat too - so you can get a situation akin to petrol fumes wafting round a smoking cigarette...
Scrunching them up in a ball and throwing them in a sawdust filled bin means that neither the heat nor the fumes can safely dissipate. And then, if they do spontaneously combust, there are usually combustibles with them in the bin. And the owner is usually in the kitchen making a cup of tea... You can see what can - and does - happen.
Basically, my understanding is that once they have been used, they should be laid out flat, away from any combustibles and in a well ventilated area until they are completely dry. Once they are completely dry, I believe they can be disposed of in the normal fashion.
To make doubly sure I haven't missed anything, do a quick google on disposal of lacquer rags to confirm.
Similar to above, I leave them on our garage floor to dry and then dispose of with the rest of the rubbish. If using paper towels, I sometimes soak them in water and chuck out directly, as I tend to use single-use gloves (keeping hold of the soaked items when removing glove means everything is contained, and the volatiles cant go anywhere or do anything).
Adam
