If you mean it's snapped in the neck and you can't get a grip on it with anything, the best method is usually to heat it with a soldering iron - use a small amount of solder to get a good thermal contact - then when it's hot enough, just before the wood starts to smoke, let it cool down and as it does, grab the end of it with some fine-nose pliers and wind it out. The wood will shrink back more slowly than the metal so it should be possible to turn it without a huge amount of force. If you chew up the wood around the hole slightly it won't matter, as long as it's not too deep.
I broke the tremelo arm on my Strat when I was still a teenager. The threaded part was way down inside the trem block. My dad used an easy out to extract it. Was I impressed? You bet. He earned massive kudos for that.
Forum feedback thread. | G&B interview #1 & #2 | https://www.instagram.com/_harry_seven_/
That’s why I prefer to use heat to get the broken screw out - even if the hole then needs repairing, it’s stronger.
