First use a drill that only just fits through the body holes, and use it to make shallow holes in the neck - just through the surface - that will make sure the holes are perfectly centred.
Then use the right drill for the screw holes into the neck - drill through the body into the neck, keeping the drill centred in the holes - that will ensure they're vertical.
Mark the total length of the screws on the drill bit!
