The black wire is part of the controls grounding. Looking at your wiring, I see no wire running to the vibrato spring tension adjustment "claw".
The white wire is probably intended to carry a signal.
EITHER - between the selector switch and the volume pot input terminal
OR - between the SPDT switch and the terminal for whichever pickup you wish to make switchable.
TBH, a photograph from a different angle would help clarify matters.
Brilliant. Thanks. There is a ground wire to the tremolo spring, it's on a screw which goes to the body.
Which angle do you need to see?
More Strat wiring https://imgur.com/gallery/MUtGg8y
The unconnected end of the white wire should be soldered into the input terminal of the volume pot.
The unconnected end of the black wire should be soldered into the chassis of the upper tone pot. It completes the ground path between all three pickups and the output jack socket.
Weirdly, the top tone control now does nothing and the bottom one controls all three pickups. Also there is a very slight hum through the amp.
I'll have a look. Seems a bit of a bird's nest to me!
