Steel isn't necessarily the best though. Following that success I also put a steel block on a maple neck partscaster Strat, and whilst it also sounded big, it was too bright. That guitar now has a brass block, which has pulled back the treble and balanced that guitar. I guess understanding your guitar is critical before choosing steel or brass, though I'd guess steel is right in the majority of cases.
Of course, if you have hot pickups, play with a ton of gain, or have a very processed sound you might miss the differences, but I can hear them whilst playing unplugged. To my mind, changing pickups will probably make a more dramatic tonal difference, particularly if you made a dramatic change (e.g. vintage to hot). However, without a decent trem system, I don't think you hear 100% of what your pickups have to offer. The difference a quality block makes is difficult to describe, but I feel the guitar has a bigger sound with more authority - I guess there is more going on in the low mids and the delivery of the sound is different - dynamics I suppose? Personally, I need to have the trem sorted first before I can make an objective decision about pickups. Other folks seem happy to spend money swapping out pickups and ignore the trem - each to their own and all that.
http://www.thefretboard.co.uk/discussion/89942/caspercaster#latest
The Callaham is first class, but expensive. It does make a tonal difference and is brighter but it's super smooth and stable, I'd thoroughly recommend it.
You may find this interesting.
My Gotoh 510 Tremolo Strat sounded dull (less treble) both acoustically and amplified compared to my hardtail Strat. So I swapped out the zinc FST block for a identical steel FST block (made for me by Kevin Hurley). I put the same strings back on - that was a bit of a faff
It’s easiest if you use an old biro tube or the one you get with a can of WD-40 - poke the tube down through the bridge, fit the end of the string into it, then push the string through and the tube will guide it.
