Need to look at it from more angles though.
Although the photo resolution isn't good enough to be completely sure, I would say that the frets are unevenly dressed and/or uneven heights - for example, the 12th fret is less heavily dressed in the middle of the fingerboard - compare the 11th, 12th and 13th frets under the G string; and the 13th and 14th frets under the low E string - the 13th is lower and more flatted if you look at the reflection of the string.
https://ibb.co/zWcq7xd
The lacquer ripple alongside the frets indicates that the slots have been cut roughly too. If it wasn't new I would guess it had been refretted.
Flat fret crowns, crude-looking, scratchy/grubby.
Inlays prepped by mini JCB.
"Mastercaster" - cute name.
