I find this wiring scheme fascinating since it uses the Ibanez 2502N switch, which I understand is internally wired differently.
The interesting part is that in
Position 2: Inner coil of both humbuckers in parallel (a bit like position 2 on a Strat )
Position 4: Neck humbucker both coils in parallel (a bit like a neck single coil)
[Imgur](https://i.imgur.com/ZE7DRFx.jpg)
When we tried replacing the ceramic humbuckers with a set of Seymour Duncan Alnico JB and Jazz - it was interesting that in position 2 it wasn’t both inner coils that were active but the inner coil of the bridge HB and the headstock side coil of the neck HB (and they weren't hum-cancelling either)
So are DiMarzio / Ibanez neck humbuckers wired differently?
With wind & polarity identical to the bridge humbucker?
To fix this with the Duncans you need to flip the magnet in the neck pickup and swap the black and green wires, which will also change which coil remains on when split.
As ICBM points out, in order to preserve noise-cancellation in all switch positions, the Ibanez and PRS circuits require one humbucker to be of opposite magnetic polarity to the other.
In some DiMarzio humbuckers, the bar magnet is glued into position. The only way to reverse the magnetic polarity is to install the DiMarzio humbucker rotated through one hundred and eighty degrees. (Good thing the twelve Allen screw polepieces look the same either way around.)
Obviously you have to swap the wiring round as well in order to select which coil is on. If the pickup is normally wired green-white-black-red, it now needs to be black-red-green-white - so the electrical phase stays the same.
[Imgur](https://i.imgur.com/qt5Z5Lh.png)
So I would flip the neck magnet - I figured out how to do that.
What do I then do with the soldering connections on the switch please? The same as the diagram below?
