It will be difficult to assist otherwise.
hopefully this gives an idea
Slow the riff down, play it as cleanly as you can and show us an angle that reveals both hands.
Also try it clean, rather than gained up- it could be something as simple as too much gain.
Just put up with it? You do hear finger slides a lot even on produced albums, it's sometimes hard to avoid.
However, if you really want to avoid it, just lift your finger up more while you slide your hand, sorry if that's stating the obvious!
Also how are your finger tip callouses? I find if mine soften up they squeak more. I’ve even found lightly emery boarding finger tips helps.
There’s also half rounds or ground wound strings but I found the loss of top end unacceptable.
Is your mic (or mic on your camera) possibly acoustically picking up the squeak? If that's a possibility, try turning up the amp or recording direct into your computer. I just tried playing it and, whilst I wouldn't claim it was completely squeak free, the squeak didn't seem as obvious.
