Right !
I’m having a bit of a back & forth with a bloke on a Jazzmaster/Jaguar page and I wanted to check my logic with the Fretboard hive mind.
There’s a guy who wants to stick a neck with a 7.25”-9.5” compound rad board on his guitar and he’s asking what radius bridge he should buy.
I’m saying that logically it should continue the “cone” radius and be flatter (although probably not much) than 9.5”.
There’s another guy that’s saying that as the radius only matters over the fingerboard section then 9.5” is fine.
To my mind that’s wrong because if the bridge is 9.5” then at the 21st fret the string radius will be tighter than 9.5” and so the middle strings will be further off the fingerboard ?
What say you ?
Regardless, your theory is sound for achieving a perfect string height profile across the board.
To be exact, a compound radius which increases from 7.25" to 9.5" from nut to approximately the 24th fret (ie by 2.25") would increase by another 0.75" (a third again) if the fingerboard went all the way to the bridge, so the *minimum* radius of bridge that would be correct is 10.25", but because of the above I would probably use 12" radius.
I have 7.25 to 9.5 fretboards and love how they feel personally
(formerly customkits)
