I'm putting together a partscaster Tele. The body is from a Mexican roadworn, and I bought a 2 piece walnut neck made by a local luthier.
The neck is very slim, and it is maybe less than 1mm narrower than the pocket.
The problem I'm having is the low E coming off the edge of the board. I'm using a Wilkinson bridge with 54mm spacing.
Is it possible to find a vintage size 4 screw bridge, with 2-1/16 (52.5mm) string spacing, and is also a toploader rather than string-through?
I've seen some bridges with the narrow spacing, but they look longer and wider with the pickup hole in a different position relative to the screws.
This is what I would do.
Alternatively, find pre-slotted saddles with the string grooves made at the desired spacing.
Then I turned the E saddle around so that the string is on the other side of the screw. However, it means that the string spacing between E and A is a bit closer than usual.
https://imgur.com/a/hIpiu1F
