Right then - how DO you get a plectrum out from inside an acoustic?
I've had a plectrum rattling around inside my acoustic for weeks and no amount of shaking will get it to fall out!
Let's have your tried and tested methods.
  • HeelHeel Frets: 271
    Flip. Hold up in the air. Look in soundhole. Jiggle guitar and watch for plectrum.
  • FuengiFuengi Frets: 2850
    Get it under the sound hole. Grab a pencil, push it into the hole and push down on the pick. Turn the guitar upside down. Release the pencil. Bingo!
  • I jiggle till it's under the soundhole and the guitar is flat. I then turn the guitar over and out it pops.
  • phil_bphil_b Frets: 2010
    cut a large square hole in the back and it will come out easily
    6reaction image LOL 0reaction image Wow! 2reaction image Wisdom
  • PhilW1PhilW1 Frets: 941
    Jigsaw.
  • VimFuegoVimFuego Frets: 15488
    I believe the correct order is put a spider in there, then a bird to get the spider, and so on.
  • merlinmerlin Frets: 6683
    edited September 2019
    Get a space craft. Fly into space. Nuke Earth and offending instrument. If you can't afford a space craft and nuke then the pencil trick is good. Attach a blob of blutack is a good option too.
  • prowlaprowla Frets: 4920
    Just get a plectrum magnet.
  • munckeemunckee Frets: 12357
    Pencil with blue tack on the end.
    Clever.
  • KilgoreKilgore Frets: 8600
    The pick will have damaged the guitar beyond repair, buy a new and better guitar.
  • Play fingerstyle.
    Haha.
    This works well for picks but is a bit time consuming if your kid's dropped a handful of Lego inside.
  • JezWyndJezWynd Frets: 6060
    4reaction image LOL 0reaction image Wow! 1reaction image Wisdom
  • droflufdrofluf Frets: 3691
    Fill the guitar with water, hopefully the plectrum will float to the top and you’ll be able to reach it more easily.
    This method is only effective for buoyant plectrums.
    7reaction image LOL 0reaction image Wow! 1reaction image Wisdom
    Use a vacuum cleaner.
    Either in suck mode or blow (don't forget to empty the bag first).
  • Small children they say the wire hurts but it builds character I say
    Shake, rattle and roll.
  • DiscoStuDiscoStu Frets: 5467
    Top ideas! It finally came out after shoogle #38 but the pencil/blu tack idea is sound and is noted for future lazy finger moments.
    Heel said:
    Clever.
    Hmmm. I'm going to sulk. I mentioned blu tack on a pencil two posts before munckee but I didn't get a WIS nor a "clever". Petulant and sitting in the corner face is now on.
