Hi there,
I was wondering if anyone would be able to help me.
i am trying to create a video of myself playing electric guitar over a backing track.
My current setup is Korg AX3000 connected to Mac via mono to input on Mac. No problem recording audio on reaper. So I tried to play backing track on Mac and port to aux in on Korg.
Monitor on headphones and can hear both but when record only guitar is recording.
am I doing something wrong or is there something additional that I need in order to have a 2nd input for the Mac?
any help would be greatly appreciated
1) Create a backing track in Reaper.
2) Play the backing track in Reaper and record your playing on another track in Reaper, whilst videoing.
3) Enable view 'Video Window' in Reaper. Drag the video file into Reaper, which will create a new track, that you can then drag (with snapping disabled) to sync the video to the other two tracks. You might want to mute any audio on the video track as well.
Then you can use Reaper to render all three tracks to a video file with the audio.
It works for me. What happens when you drag an mp4 into Reaper?
I find it a bit of a fiddle to sync the video track with the audio. Aligning the audio waveform on the video track (recorded by my webcam) with the waveforms on the audio tracks (recorded via my audio interface) still makes things look a bit out of sync. So it ends up being trial and error. Does anyone know of a neat trick to make the video and audio alignment easier.
For manually syncing the easiest way to do it is give yourself some pre roll then record a clap, or hit the strings if you’re not using a mic and going direct. That way you have a definitive point in both waveforms and a visual cue in the video to sync everything up. Trim off the pre roll at the start and you’re good to go. For fine tuning I find it easier and more accurate to use keyboard shortcuts to nudge clips in the timeline rather than mouse and dragging.
Or use Premiere which will do it all for you without needing a clap (right click > synchronise by waveform, delete your camera audio, done)
https://youtu.be/Mjx_GjyXCs4
