Some use a contact spray cleaner as part of a regular service - Maybe once a year is enough
If to oxidised and causing an issue I use a piece of fine wet n dry to clean contacts with a slight rub, even on the 3 way LP style switches and jack socket
Lack of use is often a cause of such issues
Just that the article was about cable capacitance which made me wonder.
https://sixstringsupplies.co.uk/
Our YouTube Channel for handy "How-To" Wiring Tutorials
I would also not use sandpaper unless it's *extremely* fine grade - if you scratch off the nickel, chrome or gold plating you will just increase the rate of corrosion and the problem will come back quicker.
Don't replace a decent-quality socket either - ie a US Switchcraft, Neutrik, Cliff etc - almost all the time, the contacts just need cleaning and in some cases bending slightly back into position. Replacing cheaper far-east sockets is worthwhile though.
I use a simple tool that I made from an old solid brass plug - I heavily scratched the barrel of it and the groove around the tip in a sort of 'swirl' pattern using sandpaper. I simply squirt some contact cleaner into the jack, put the plug in and out a few times and spin it round, and the job is done - usually if you wipe the plug, a lot of greenish muck then comes off...
Suppose it's not going to do any harm to give them a gentle clean from time to time.
I also had to replace the jack socket on my JMP-1 for the same reason ... or rather I left the old one at the front and drilled a hole and fitted another one at the rear ... which makes more sense in a rack setup.
It's a good idea to clean the jack sockets of a serial effects loop on your amp if you don't use it ... as the socket here acts as a closed switch when you don't use the loop... and over time corrosion will cause all kinds of problems like intermittent volume or almost complete loss of signal. Likewise the insert jack point on a mixing desk channel which operates in the same way.
Ultimately it's a shit design all round but we've stuck with it.
So what do you think is actually happening? PART of the signal being lost?
