I've just sprayed a tele body Inca silver in rattle can nitro. Clear coat top.
How long do you wait to flat sand and buff, and what process do you use, as in what grits do you work through and what do you buff with at the end?
The body looks pretty good, I think it will come out okay. The finish is uniform but quite a rough texture, not smooth orange peel.
I tried to go with thicker wet coats but the clear just turned to milk. Fortunately, a very light coat at the end made it clear again.
Not sure why it went milky, humidity was less than 50% and temperature was just over 20. But looked okay at the end.
Are metallics harder to spray generally?
