Perhaps the most famous and beautifully designed system is the one on Ibanez guitars with the five way switch.
[Imgur](
https://i.imgur.com/ZE7DRFx.jpg)
Positions one, three, and five are obvious.
1. Bridge Humbucker
3. Both Humbuckers
5. Neck Humbucker
Positions 2 and 4 involve splitting the coils.
2: The inside coil of each pick up (a bit like position 2 on the Stratocaster)
4. Both coils of the neck pick up in paralle (a bit like the neck pick up on a Strat)
Both of these do a decent impression of what they are trying to mimic but there is a significant volume drop in positions 2 dan 4. I suppose you can use this creatively to 'clean up' the sound...
There is however, another single coil emulation technique which involves installing a 0.1uf capacitor along the humbucker's shunted series connection’s path to ground.
This is not a new thing - but I first saw it on a Guthrie Govan Charvel I used to have...
1. Not quite so impeccable hum-cancellation
2. A superior single coil sound (with preserved mids if you add a resistor)
3. Much less volume drop
In conjunction with a three way switch and push-push pots you can render each (or both) humbuckers in 'single coil mode' so allows you 5 extra sounds (for a total of 8 sounds)
Bridge single coil
Neck single coil
Both single coils
Bridge Humbucker + Neck Single Coil
Neck Humbucker + Bridge Single Coil
I think I prefer this configuration - will post some audio files soon...
I configured my switch to offer the obvious neck, both, bridge on one side. The second side was power-out-of-phase, inside coils in phase in parallel and split bridge HB.
I don’t much rate the split HFS. If I ever think of anything better, I shall rewire the Freeway.
You get the fatness of a humbucker with A little single coil sparkle on top :-)
Not a fan of push/pull pots personally.
https://www.thefretboard.co.uk/discussion/207596/bolters
Push-Pull are a pain...
1-Bridge HB
2-outer coils of both HB's
3- both HBs
4 Inner coils both HBs
5 neck HB
I found it really usable.
Got get Master Volume, 3 way toggle, Master Tone (treble roll off), Preamp level knob
The three switches are independent splits for the pickups, and phase reversal.
The last mini switch is preamp on or off - nice onboard selectable and tweakable boost)
The chicken head knob is a Varitone with different selectable loads of filters or something.
All of these are really good and useful...apart from the Varitone, which makes the entire guitar sound progressively shitter as you go through the settings. So it stays in the off position.
* Hamer Watson, SS2, Vintage S, T62.
* Music Man Luke 1, Luke II
Please drop me a message.
