Downward pressure on the pot shaft can be enough to distort the bottom of the casing. This, in turn, reduces the firmness of physical contact between the resistance track and the wiper contacts. Even pressing a control knob onto the shaft too firmly can be enough to distort the casing.
Another possibility is that, in the tangle of wires tucked under the pickguard, something is intermittently touching something else that it should not, causing a short to ground and killing the signal.
I think I understand the last paragraph, but the first two are completely over my head!
If it goes to complete silence it's a short - something touching where it shouldn't be, or possibly a faulty jack - and if there's residual noise it's an open circuit.
Does it affect both pickups or just the neck? If both, it's something between the switch and the jack. If just the neck, between the pickup and the switch.
The most obvious fault is that there's inadequate grounding - using the shielding foil to make the ground connections between the pots is prone to causing trouble. Solder a wire between all the pot casings.
It goes to complete silence, so I presume it's something between the switch and the jack then?
I'll have a look at the grounding wire tomorrow.
When I took the scratchplate off, it seemed also some of the solder joints for the selector switch had come off, and the grounding wire had come off the pot. I resoldered them all and made sure all wiring wasn't touching the scratchplate and it seems to working well for now.
The guitar's a Squier Joe Trohmann, so a Tele Deluxe and they are a real PITA in taking off so many screws etc. Sure there are worse guitars though!
Thanks again @ICBM!
