Okay so I have a Charvel pro mod, one of the newer Mexican models with the floating Floyd.
I blocked it off using a stack of coins taped using electrical tape. Put 5 springs in the back and tightened them as far as they will go. So my makeshift blocking mechanism (coins) is holding tightly in place, the trem certainly won’t budge back, and takes an almighty effort to push it forward, so everything seems solid.
The trem is perfectly parallel to the body so no issues there.
im still having an issue with the top e and b strings drifting sharp. This is with the locking nut slackened off. Anyone know what could cause this? Do I just need to let it settle for a while?
If the Floyd won’t physically move in either direction with it setup as you have described then all should be good, and using the fine tuners is probably the only thing I like about Floyd’s.
I'm not saying you can't get it to work mind, maybe with some sort of lubrication.
With all that said, wtf do I know. I could be talking out my arse again.
Then I seen the comments above!!
So that would explain why the 2 strings were drifting sharp, they must have been dragging ever so slightly on the nut.
Once I’ve locked it down it’s all stable and staying in tune so all is well again.
Thanks for everyone’s help.
I've got a schaller floyd on one guitar and a couple of Ibanez floaters too and staying in tune is totally not an issue. They go into the case in tune and come out the same way. Obviously more hassle changing strings, but once it's up and running, no problem at all.
I own a guitar with a floating Kahler flyer and a few few conventional strat type trems and out of all of them its the strat type trems that are the hardest by far to keep in tune.
Just saying like
One of my guitars now has a Schaller Trem Stop on it. Bloody ugly thing, but locks the trem in case you break a string or want to do some double stop bends.
https://images.app.goo.gl/EwvboEs5KBDEJfx1A
The only thing that can beat it is an Evertune, and that's really a totally different approach to stability.
