Presumably, this is engaged via a push-pull pot? IMHO, without the third coil of the real thing, series/parallel switching might prove more useful. Parallel is the normal sound. Series is slightly louder and considerably thicker - to the extent that you may consider it dull and barely usable.
Stunning value! That figure would not buy an American-made replacement pickup.
No push-pull. There are two volumes (one for each half of the humbucker) and one tone pot.
Wiring mod/upgrade suggestions, in order of difficulty and expense;
* Two-way = Parallel mode / partial coil split. Three-way = Series/Split/Parallel.
You're forgetting -
0. Master vol, passive bass cut, standard tone control - by far the easiest, and most useful apart from a full active preamp. All you need is one little capacitor - .0047uF, not .047uF which is the standard tone cap value.
