I usually have at least 2 other tracks running LABS strings and keys, and 2 instances of Kontakt with eurobass.
Point being, thats a fair few samples being loaded into ram, so I doubt the problem is your library, the kit in SSD5 is about 2 gig, for example.
There is a bottleneck somewhere, but I doubt it is your drum folder, I would try getting a cheap USB external for an archive of the samples, and clear your system drive to give the OS some space. Both my systems have about 100gig free, and I think my bottleneck is the ram.
note though that when I run huge projects [especially orchestral] I still get glitching from several instruments..
to solve it I freeze tracks in Logic
If not, I'd guess you could pretty easily afford to choose the "load all to RAM" option if you've got 32gb?
