Hi Folks,
I am in the process of tooling up and making jigs to build my first DC 59 Paul.
I am currently building a fret slot mitre box to use with my Pax fret saw and laser cut slotting template.
At present I am planning on cutting the slots before radiusing the board.
In deciding how deep to make my mitre box saw stop, for the saw back to run on, I realised I needed to calculate it so that the slot depth will be correct. My saw blade is 42mm deep and I am using a 6mm rosewood board. I was planning on using medium-wide fretwire, and am aiming for about 1.8mm slot depth. ( I think ! )
Am I in the right ballpark with 1.8mm or should I be going deeper for an unradiused board ?
. I just want to make sure that after the board is radiuses there will be sufficient slot depth left at the edges of the board.
Any advice welcomed !
Cheers
Pete
radius board...
recut slots...
Filling gaps in the slots ends with superglue and saw dust is not the end of the world though if they are too deep after you have fretted.
Keep the dust from when you radius the board.
And if you mess up a slot you can glue a piece of veneer inside it, then cut it / plane it / sand it flush and cut a new slot, the old one will most likely be hidden by the fret.
Cheers, Pete
