I would be worried about the mismatch between Fender and Gibson scale lengths and neck pitch angles.
It's already bad enough with the telemaster, leave the explorer alone you swine
:-p
OPTION #1
Stick with mostly Gibson-style fittings but improvise a Parfitt-style cut down Telecaster bridge plate to mount the bridge/Treble pickup.
OPTION #2
Bespoke variant of Oil City Pickups Big Block. (Ostensibly, a Sixties style Telecaster bridge/Treble pickup in an open top humbucker cover.) I dare say that, for a nominal upcharge, the Big Block design could be adapted to house a Wapping Wharf tapped Telecaster model.
OPTION #3
Purchase a left-handed example of the early, US-made, Fender Meteora and play it upside down à la Hendrix.
(formerly customkits)
I have made many Explorer/casters, and LPJ / casters, a few tips if you'll going to have one made, stay away from Mahogany, too heavy, that much heavy wood takes away the classic Tele sound. Although a standard Tele body made from Mahogany that's fully chambered sounds just like a Tele should. Even if you go to Swamp Ash or Alder, I would be tempted the have it fully chambered, even then it will most likely be heavier than a standard Tele. The last few I've made have been made from light weight Idigbo, Obeche or Basswood.
Your life will improve when you realise it’s better to be alone than chase people who do not really care about you. Saying YES to happiness means learning to say NO to things and people that stress you out.
Is this something you could help me with?
