Strap weight eureka
TINMAN82TINMAN82 Frets: 1846
Not sure why it hadn’t occurred to me earlier that the weight of the strap adds to the weight of a guitar and therefore the benefit of a wider strap might be negated by its weight.
Some of us nit pick over ounces here and there (see R8 thread as a prime example).
It turns out that my garment leather Levy’s M7gg3 (3inches wide) strap plus strap locks is over 15ozs (nearly a pound)! Yet I’ve been using it in the false belief it’s easier on the shoulder with my 9lb R8. A chance comparison with a cheap Ernie ball polyprop strap (2inches wide, 5oz weight) and the R8 instantly felt lighter and more comfortable.
Probably irrelevant for most strats/Teles etc that are under 8lbs but for the Les Paul that 10oz difference is worth noting.
  • bbill335bbill335 Frets: 1391
    yeah, i had one of those thick plush leather straps on my slightly-heavy strat for ages, but i've found souldiers much more comfortable.
    I put up a special erection that supports my guitars.
  • Well, it's a neat trick if you can do it, but be careful balancing a weighty R8 on it, you could do yourself a terrible injury.
  • p90foolp90fool Frets: 31751
    I hope you get those little blue pills on prescription, otherwise it would be cheaper just to get a guitar strap.
    I can get mine over the counter.
  • Paul_CPaul_C Frets: 7862
    That sounds impressive, but I bet it alarms the chemist.
  • JohnS37JohnS37 Frets: 351
    Old car seatbelt webbing works a treat.  It’s really light, quite comfortable and you just flame the ends to stop them fraying, and melt holes in either end.  Works for me!
    Doesn't that work out a bit expensive if you have to buy a car every time you want a new strap?
  • I aim for the lightest possible guitars to alleviate the effects of my weighty strap....
