Ibanez Soundtank - accessing / removing circuit board
Have a few of these that are in need of either tweeking - DL5  and TS5 - that has flakey input jack - that probably needs a touch of soldering iron ,,  but I cant get the boards out ... any advice appreciated .
btw I cant get the control knobs either atm
  • ICBMICBM Frets: 72850
    It's a while since I worked on one, but I seem to remember that all you have to do is get the knobs off, and the whole PCB comes out. Getting the knobs off is difficult - if you can't pull hard enough to get them to shift you need to get the tip of a small screwdriver under them.
    many thanks - delicate approach noted ..
    edited November 2019
    worked a treat thanks - the knobs extend a fair way into the pedal chassis - but once they were off , simple enough  to get board out ..
    input socket n power supply joints now solid
    will do 808 mods - n see how its compares to my ts9 if indeed there's any real discernible difference ...
    If I remember rightly it’s identical to the TS-9.
    Save yourself the bother of the 808 mods, unless you’re really curious - I fitted an old TS-9 with a switch to select the 808 values and it made no detectable difference at all.
    While it may be true that some 808s sound different to some 9s, it’s down to component tolerance variations, and you can usually find differences even with the same models.
    Some 9s did use a different chip, and they really do sound different, but any 9 or 808 circuit with a 4558 should sound essentially the same.
    it was essentially out of curiosity - I've found Brian Wampler Indy guitarist pdf's recently n Im amusing myself just trying some of the mods on low cost platforms - though tbh the TS 5 does sound more than acceptable .  I will be ab'ing it with my TS9 on a true bypass looper just to see how how close they really are .  perhaps the Brent Mason mod may have a more appreciable difference ..
