Electro-acoustic Problems
Hi all.
I have a Yamaha Compass CPX-5 TBB Electro-acoustic guitar.
The electronic part of this is not working. Does anyone know how to fault find the EQ panel in the body of the guitar.
Alternatively does anyone know where you can buy a replacement for it.
Kind Regards
David
  • ICBMICBM Frets: 72778
    If the problem is in the preamp itself, it's unlikely to be repairable and you'll need a replacement unit.
    Yamaha UK are very helpful in my experience - https://uk.yamaha.com/en/support/contacts/index.html
    We also have a Yamaha person here on the forum who might be able to help - @rossyamaha ;
  • SteveRobinsonSteveRobinson Frets: 7091
    Faults are almost always to do with the connecting wires rather than the preamp itself.
    I do have a new preamp in my parts box should you need one.
  • Thanks Steve. I’ll check out the cabling.
    Cheers
    David
  • FunkfingersFunkfingers Frets: 14615
    Did the electronics cease working suddenly or gradually turn farty over several weeks before cutting out? (Onboard battery failure.)
    Faults are almost always to do with the connecting wires.
    My first ports of call would be the output jack socket and the PP3 clip. No power supply, no nuffink!
  • Thanks for reply.
