b) Learn to play upside down
c) Learn/pay someone to swap the nut, bridge and scratchplate around
d) Flog it and buy a righty
You cannot properly convert a left-handed steel-string acoustic to right-handed (or vice versa) because not only is the pickguard on the opposite side and the bridge saddle angle and intonation the other way round, the bracing on the inside is asymetrical as well.
Contrary to popular belief, for most guitars asymmetric bracing systems do not affect the tone or structure of the guitar if the strings are changed round. It is easy to try it before any changes to be sure.
1) change the strings round to right-handed
2) use a capo to get rid of the nut issue
3) if you want fretboard side dot markers, use something like the Jocomo removable stick on type (about £5)
4) Put up with the intonation issues from having the saddle angle going the wrong way in the bridge - the impact isn't that pronounced unless you've got a sensitive ear for pitch - and can be improved slightly with a new left-handed compensated saddle (about £10)
If you still love the guitar after playing it a while like this then it may be worth getting a more permanent conversion. If not - it can easily go back to being left-handed for you to sell it on if you wish.
You can also be sure that the tone is not affected by changing the strings round - which I think is unlikely to be an issue.
This guitar isn't the perfect candidate for conversion (e.g. the pickguard) - but if you really want to have a go then try my reversible quick and dirty approach mentioned above and see how you get on first.
If you are subsequently convinced you want to go the whole hog, It helps if you've got a friendly neighbourhood luthier who charges realistic prices for the work rather than some of the exorbitant quotes I've seen for run-of-the-mill stuff. I would strongly recommend against trying full conversion work on a guitar like this yourself.
A right-to-left conversion can be acceptable due to the rarity of left-handed guitars, but doing the reverse to a left-handed guitar - especially something as good and rare as this - is just stupid. Decent left-handed guitars are hard enough to find for left-handed players without ruining one unnecessarily.
I do major mods on all types of guitars. I also make high quality acoustics. I would NEVER do a mod like this to an acoustic.
While you can take major liberties with solid basses and guitars, acoustics are built left handed or righthanded. Modding it would destroy the sound. Modding it would destroy the value.
A proper conversion would cost money, the guitar would look odd (pickguard) and the value would be impacted.
However, it is unlikely that there would be any impact on tone or playability with the end result if done properly (I speak from practical experience and the advice of several notable luthiers) and this can be tested before any work is carried out.
